raptordoke
I picked up a 2018 last weekend. I was able to detail the engine bay and did a one stage paint correction. I may be answering my own question here but am trying to see if anyone has a better one step polish recommendation. I did a citrus bath, medium yellow clay then I used chemical guys vss with an orange hex logic pad with my DA. Followed that up with jet seal using a black hex logic pad. From a distance is looks great but up close and under lighting I am still seeing the swirls and some pin striping. In the past I used m105 and m205 … but was seeing if there was something better out there. I don’t think it is bad enough that it needs wet sanding, but wasn’t sure how far I can push the paint.
