NAVTV Module in my 2014
caisaacson
Tennessee
Just in case anyone is wondering, i recently installed a NAVTV module in my 2014 and I have to say it was EASY!!!
The directions lead you to believe that a ton of soldering is required but the ONLY connection needing to be soldered is the one for your front camera. Past that it was literally plug and play.
Note: If following installation your rear differential is permanently locked and 4x4 system is not working then take a deep breath. Following the deep breath, disassemble your dash and plug in the connector that feeds your 4x4 knob. I learned that the hard way.
BAJASVT
SE Michigan
Thanks for the update.
I read a little on the FIM Lockpick, but I'm pretty sure that I want to go with the Nav-TV.
How do you activate your front and rear cameras?
The Car Stereo Company
here, on frf
the units made last year for the 13s you had to cut a bunch of wires. now they came out with the new plug n play harness, so all you need to interface is the front camera wire.
in the truck apps, you can turn your front camera on anytime. to activate the rear camera, double tap the rear defroster. you can double tap again to toggle between front and rear, except while in reverse. then the rear camera takes priority
CrownOffroad
San Diego, CA
I've got one of the '13 units that require all the cutting. Any way to get one of these plug and play harnesses for the last model?
BAJASVT
SE Michigan
Is there any way to use a toggle switch or an aux switch for the cameras?
here, on frf
someone said they had info on this, but i dont know who. and it seemed like a lot of work. i will have to contact nav tv tomorrow and see what they say
Wfo
Syracuse
Any word on a plug and play harness ? With the exception of the front camera .
Az Scooter
And, for those of you that want to do this mod, there is a group buy going on in this very forum. Join in. I think we need 6 more people to get 25% off.
