My Raptor has a warped door
RaptorMY23
Illinois
Just noticed that my passenger front door is warped. Ive not come across this before on any of my rides. I've attached a pic of it, and the driver"s side for comparison.
Is this something I should have Ford fix? Am I being picky?
The door is closed all the way.
CoronaRaptor
CANADA
Looks like it just needs the door striker adjusted a bit. Shouldn't be a big deal. I would want it to fit a bit tighter against the door seals, etc. Should take less than 5 minutes to adjust. If your ****, you could do it yourself instead of having the stealership touch it.
EricM
OHIO
Am I being picky?
That wide flat part on the door that your are looking at is a separately applied trim piece. It's likely just not applied right, and no tweaking of the door will fix that. The top of the doors above the trim look like they line up fine. They'd have to pull that trim piece and try a new one. Not a big deal for a body shop.
Jake226
IN
You’re not being picky. It’s your truck. You deserve to have it assembled correctly. Just as the others have mentioned, make sure you get it into a shop where the “fix” will make your truck better, not worse.
Oldfart
When I got my '20 the shut lines were terrible on the front passenger door, and the hood was a little crooked that it actually had very slight metal to metal contact on front drivers corner. The dealer sent it out to a body shop they use and everything was fine when it came back. It does suck when you see that on a brand new truck though.
