Musy smell
Devildog1775
Leonardtown, MD
I have a 2018 and it is starting to smell musty on the inside. It's not coming from the vents and I can't find any wet carpet. Any ideas? The only thing that has changed is I don't drive the truck much lately.
JorgesRaptor
Seattle
I changed it and it helped a little but the truck still smells.
Hmm well if that helped maybe it is in your system? My BMW has it happen pretty frequently, I just run a bottle of Ozium sanitizer spray for a while then let the system recirc for a while
Another thought may be your windshield washer fluid
2020FordRaptor
Nevada
So what happens, is if you have the AC on while driving yhe truck and you park it for long periods of time, the mildew from the AC can make an odor that comes through the vents. A way to make sure that doesn't happen is to blast the heater before shutting it off so that water is evaporated.
thatJeepguy
GA
Rent or buy a commercial grade ozone generator , pull any rubber mats,and leave it running for 3-4 hours with all doors closed. Air it out and repeat if needed. Do not allow yourself or anyone, or pet be in it while that thing is running, as its harmful to be exposed.
After that id check for leaks… sun roof drain hoses ?
BWorkman
Altadena, CA
I had a problem where the truck was building up moisture underneath the rear seats when it rained hard. Might want to check and see if there’s any moisture there as well. I haven’t been driving my truck a lot either and put a box of baking soda under the driver seat and that seemed to help a little as well.
Nex
RIP CoronaRaptor
Washington State
Check your rear cab vents.
