Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Exterior Modifications Forum [GEN 1]
Mountain Bike Bed Rack/Holder
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="M3 WRATH" data-source="post: 180169" data-attributes="member: 968"><p>Every bike I have is too long to keep both wheels mounted and have it sit straight in the bed (too slack of a head angle I guess) so I decided to get a front axle mount from Rocky Mounts. It is lockable so it does give some level of security. I had a local fabricator (the line-x guy actually) make a steel bar that goes from one side of the bed to the other and I bolted it into the existing tie down holes (so completely removable without leaving any trace behind). I then had the tie downs attached to the steel bar so I could still use them when necessary. I attached two Rocky Mount HD mounts to the steel bar (one to each side of my spare tire so I can haul two bikes) and had the whole thing coated with line-x (pretty convenient since he was also the fabricator!). It cost me $100 for the fabrication, $100 for line-x, and $79 per mount. I know its not as cheap as some hitch mount bike racks but it's secure, unobtrusive, and looks pretty clean and custom (in my opinion). I just wanted to show that you have some options and hopefully this will give you some ideas for your dream bike rack. My front tire fits really well in the space between the bar and the front of the bed. My spare tire keeps it from rolling back and forth, but you could easily have a small piece welded on to the steel bar to keep the tire in place.</p></blockquote><p></p>
[QUOTE="M3 WRATH, post: 180169, member: 968"] Every bike I have is too long to keep both wheels mounted and have it sit straight in the bed (too slack of a head angle I guess) so I decided to get a front axle mount from Rocky Mounts. It is lockable so it does give some level of security. I had a local fabricator (the line-x guy actually) make a steel bar that goes from one side of the bed to the other and I bolted it into the existing tie down holes (so completely removable without leaving any trace behind). I then had the tie downs attached to the steel bar so I could still use them when necessary. I attached two Rocky Mount HD mounts to the steel bar (one to each side of my spare tire so I can haul two bikes) and had the whole thing coated with line-x (pretty convenient since he was also the fabricator!). It cost me $100 for the fabrication, $100 for line-x, and $79 per mount. I know its not as cheap as some hitch mount bike racks but it's secure, unobtrusive, and looks pretty clean and custom (in my opinion). I just wanted to show that you have some options and hopefully this will give you some ideas for your dream bike rack. My front tire fits really well in the space between the bar and the front of the bed. My spare tire keeps it from rolling back and forth, but you could easily have a small piece welded on to the steel bar to keep the tire in place. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
Sierra117
bne
RapidRed25Raptor
patwusmc
supa-clean
Oxford Raptor
Hard R
fat dude
downforce137
ajm2332
Super_Raptorrific
WKUSMC
Sorry About Da Noise
Stingray23
thatJeepguy
omalley72
swu011
mdamon
steem430
BLJ
cavemanwelder
RAPTOR9one6
roger7254
Brapp_rap
TYRCS
itr111
Rednose
MC817
Turning Blue
96,845
60,798
Douglasj76
Forums
Accept
Learn more…
