GEN 2 morimoto xb headlights f150 raptor 'problem with turn signal left side'
umans
belgie
good day
I bought the Morimoto XB LED (Amber) |15-17 Ford F-150 & 16-20 Raptor bulbs.
have a problem, (driver side) left turn signals not working. if I install the headlight (driver's side) on the right side it works.. have No error codes, no flickering, hyper-flashing, ..
could it be a bad ground or something to do with lights forscan settings?
(the originals oem headlight led do work)
everything else works and looks good...
with friendly greetings..
raiderofthelostark
Seattle, WA
Do you have both headlights setup the same for turns (the connected signal loom for sequential turns or disconnected for standard flashing)?
Its a single wire on both headlights with a waterproof connector. I believe its purple on one connector and green on the other.
Seems like you might have one setup differently than the other which is confusing the system
