JT52423
Hello,
I've been planning on doing the mid perch mod and some work on the weld seams to fit 37s with outrub but now considering a shock rebuild and new springs such as geiser or eibach. It seems like gesiers with mid perch will fit 37s but may make the front higher then rear? I don't want to raise rear and dont want front sitting higher then rear so would do stock with mid perch and trim or geiser springs on low perch and trim if needed. Any recommendations on set up? Thanks.
