Lost my running lights...
dataustin
Guys and gals, I could sure use your help....
Left Austin this morning on my war to Macon, Georgia pulling a 21' trailer. Everything was fine until the sun started to set and I realized I had no rear truck lights or trailer running lights. FYI, the truck and trailer both have blinker and brake lights. BTW, there are no rooms in Slidell, LA so I limped into Diamondhead, MS using my flashers. :)
Assuming there isn't a fuse involved, would you suspect that I have a short in the trailer harness?
FvilleRaptor
Pungo, VA
So I found the fuse to the rear lights and it was blown. So I replaced it and as soon as I turned on the lights it blew again. Any ideas? Is there some sort of short?
BAJASVT
SE Michigan
Disconnect the trailer plug and replace the fuse again. If it doesn't blow you'll know it's a trailer wiring issue.
