SOLD
Up for sale is a Long Teavel Bedcage Setup. Package Includes:
-Fully Tig Welded Bedcage
-Fox 3.0 Triple Bypass Shocks - 18" Travel
-Deaver +2 Springs
-Fox 2.5" Bump Stops
-Bump Cans Incorporated into Cage
-Extended Leaf Shackles.
$4,500 takes the setup.
Willing to ship or I can bring to TRR
A couple things.... This is obviously a weld in only kit. The bedcage was built a little too high in my truck so before it goes into the next truck, it should be cut down 1-2". That would be very basic to do. With cutting down the cage, the bump cans will need to be raised and this will require some minor fabrication. No more than 2-3 hours for anyone with skills. You will also need to tab your rear housing for new shock mounts and cut your bed for shock and bump stop openings. Once those changes are made, this kit should pull 17"-18" of rear wheel travel.
Pics were when it was new. Will get some current pics up shortly.
-Deaver +2 Springs
