Light Help
mwaite09
Nashville, TN
I need a little help with some new LED rear bulb replacements. I purchased 4
LUMEN® 3157CR - Tail Light Replacement LED Bulb (3157 / 4057, Red), installed them and now get the hyper flash. Not sure what to do, according to carID i need to change the bulbs around until i find the correct combination, WTF? they're all the same bulbs.
pat'sRAPTOR
Everywhere
No it's all the same haha you don't need to switch them around its gonna happen no matter where the bulbs are. To fix this you need to install a resistor on each turn signal that has an led bulb in it so it tricks the computer into thinking the stock halogen bulbs are in them. Maybe Noah can chime in and correct me but I think a 6ohm 50watt resistor will fix this.
