Leaky rear output seal normal?
Raptorbert
Hampshire, IL
Hello all,
Just got back from a dealership service visit. They took a look at some fluid splatter from the rear output transfer case area, assuming the seal needed to be replaced. You can see in the photos there is some oil splattered onto the underside of the body all around like it was spitting from the driveshaft spinning. Also that shaft is oily. It doesn’t seem bad at all, but certainly not normal. The service advisor said it is normal and that there was nothing to fix. I want to believe him but I feel like there’s no way that is a normal thing, is it?
Vehicle is a 19 with 17k miles. I bought it used still under full warranty last week.
Thanks all
Raptorbert
Raptorbert
Hampshire, IL
Unfortunately, dealers may consider a "seep" normal. it is subjective.
I cleaned it up and will keep an eye on it. If it starts seeping again I might just tackle it myself. Took them 4.5hrs ( I waited) to replace a battery, check door gaskets coolant drain and that seep only to replace the battery and send me home)
Hello all,
Thanks all
It’s a slip yoke, it’s normal to have some oil on the yoke as it moves on the output shaft. Some of that will inadvertently come off as it turns, which is what you see.
95,462
59,070
Asqrd
