korbendallas
Has anyone tried to use the low–level inputs to the factory Sony amp and go straight to the CleanSweep? It seems if there are the standard left and right, front and rear full frequency outputs, this would be the most efficient route to go. One could then remove the factory amp (save weight and power) and not use a summing device. I would think that taking two components out of the signal path would also reduce distortion to some degree also.
Quoting from the CleanSweep manual: “it accepts virtually any analog audio signal, from low-voltage line-level to high-power, amplified speaker-level, via its four differential-balanced inputs. With totally automatic level compensation, the CL441dsp converts the two or four connected analog signals to digital audio with 24 bit effective resolution.”
