Installed Foutz 2”F & .75”R
jakerjaker19
denver, co
Interesting. Im 2.25 RPGs and the Foutz .75 for level. A few of us use this combo. Quarter inch here and there is preference I suppose.
TXRaptor37
georgetown. tx
Installed Foutz 2” Collars in front and .75” rear spring spacers. Truck sits .75” higher in the rear. 37’s on a 35 Package truck.
View attachment 402661View attachment 402662
Jeddler, your truck looks awesome and love the stance with a minor rake still. Any noticeable difference in ride quality. Comfort, handling? Debating between Foutz collars or Eibach springs.
TXRaptor37
georgetown. tx
1 more ? What is your wheel offset, looks like a 00 but wanted to ask to make sure as it looks like just a little poke. Getting new wheels and debating between a 00 or +18 Thanks and any feedback would be appreciated
TXRaptor37
georgetown. tx
How’s your ride w/ the collars vs stock?
Seems like mixed feedback with some owners saying no different at all vs some saying significantly stiffer and have regrets installing them.
On the fence between a 1.5” collar vs 1” Eibach springs so any feedback would be great. Thanks
Hambone
Atlanta
Here’s a 37 with the 1” Eibachs and 37x13.5 Yokohama x-at’s on 9 x 12 offset. I think it’s the perfect stance. Ride is like stock, can’t really tell a difference
Jeddler
Jeddler
Midland, TX
Are you running 37x12.5/17s or 37x13.5/17's? Did you need to do any inner fender modifications?
Stance looks amazing!
Yes. I had done trimming prior because I swapped over my Methods 0 offset with 37/12.50/17 Ridge Grapplers from my 2019 before trading it in. I was at stock height so I had trimmed a pie shaped piece from the pinch weld. I had to trim the inside edge of the flare because it was rubbing at partial lock with the current setup.
Slightly stiffer than stock. Still rides very nice. These tires seem "cushier" than the Ridge Grapplers that I had on here before.
1 more ? What is your wheel offset, looks like a 00 bit wanted to ask to make sure as it looks like just a little poke. Getting new wheels and debating between a 00 or +18 Thanks and any feedback would be appreciated
-6 offset like BAJASVT mentioned above.
Like I mentioned above. I think tire choice(and psi) can have an effect on ride quality after the collars. It is slightly stiffer but not in a bad way (if that makes sense) it still rides very nice. My pregnant hormonal wife can't tell a difference in the ride lol
Members online
No members online now.
95,320
58,843
brucebarson
Latest posts
