Thanks for the kind words. That was arguably the most complicated video for the Ram. Hope to do one for the Raptor soon!Waterfowler, you need more love. Thanks for making a bunch of awesome DIY videos. Your RAM 3rd brake light install helped me a bunch and I'm stoked you’re part of the Raptor community.
Thanks Roger!Always good install video, i love the details you put into it. Really enjoy your video on youtube. Keep up the good work.
Unfortunately I don't have any guidance for you here as I have a 23. I guess, get the multimeter out and start searching or see if someone can give you a wiring diagram for your truck and F150LEDs can tell you which circuit you're looking for to tap into.Wondering if I could ask you for some help here I cannot find the answer to anywhere. I installed the same vent lights you had, wired to the marker lights on a 24. The wire color and location is different. The harness seems to be more towards the passenger side than centered. I was able to get it to work perfectly and plan to post what I did.
But before I do, I’m attempting to install the running board lights too. As per f150leds support, the correct wiring on a 24 is accessing the harness in the floor panel of the rear drivers side, thin black with purple stripe for ground and thin gray with purple stripe for power. I was unable to get this to work. Any ideas on what else to try? Any access to a wiring diagram for the 24s? Thank you
