ray101381
Got this installed today, very easy install.
-use some old rags and cover area below reservoir and hoses
-remove maf sensor harness
-Open reservoir
-use channel lock pliers to slide clamp back on smaller diameter hose and remove hose
-drain PS fluid into cup or some sort of pan
-squeeze clamp on bigger hose and slide off hose
-there's a clip holding a wire harness to the top of the bolt holding the reservoir on, use flat head while pulling up on wire harness and remove
-11mm deep socket remove bolt
-remove stock reservoir
-install is the reverse
-fill reservoir to line, start car, move steering wheel back and forth and check fluid.
fit and finish is top notch, very happy.
-Open reservoir
