Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Interior Modifications Forum [GEN 1]
Hydro dipped my 2011 dash panels
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BAJASVT" data-source="post: 634982" data-attributes="member: 7663"><p>Which panels started cracking and flaking? Pictures?</p><p></p><p>The dash trim panels are pretty easy to remove. The panels on each side of the radio trim are the most time consuming to remove because you have to unbolt the four center console bolts and slide it back about an inch to remove those. Also, believe you have to slightly pop out the passenger airbag to get the trim piece on the far passenger side off.</p></blockquote><p></p>
[QUOTE="BAJASVT, post: 634982, member: 7663"] Which panels started cracking and flaking? Pictures? The dash trim panels are pretty easy to remove. The panels on each side of the radio trim are the most time consuming to remove because you have to unbolt the four center console bolts and slide it back about an inch to remove those. Also, believe you have to slightly pop out the passenger airbag to get the trim piece on the far passenger side off. [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
RaptorFun
Idaho
MadZeus Darknature
Keamg5
Wobblenuts
NickyF25
nikolasschlosser2000
MackFord
Big Blue
Rosshh
450isOKforNow
OKflyswatter
raptorsub
CleverGirl_
Zeusmotorworks
jmarcil427
96,596
60,568
boomdickie
Forums
Accept
Learn more…
