is there a trick to lining up the front shock with the bolt holes? I put the old spring on my new shock, but now the bolts are misaligned. Don’t want to run a new shock. Do you just get the bolts on the holes and then use a pry bar through the bottom to rotate it around?
Any help is greatly appreciated.
