Leadfoot's Orange Crush
- Joined
- Sep 15, 2010
- Posts
- 50
- Reaction score
- 1
How to: FOX RACING SHOX / Perch Adjustment
"A BIG Thanks to my Buddy Trevor @ Whitby Transmission!"
Good day Folks!
I just got back from Trevor's Shop after completing the factory shock adjustment.
No need to remove any parts of the suspension. Here it is in simple steps.
Step 1- Remove the wheels.
Step 2- Apply the spring compressor
Step 3- Remove the set screw in the blue ring and slide it up to reveal the retainer spring clip.
Step 4- Move Spring clip up to the desired setting. (There are 2 above factory.)
Step 5- Install the set screw and release spring clamp. DONE!
We went up one adjustment notch to the middle position as you will see in the photo's for a total gain of 1 3/4" overall to the bottom of the fender of sprung weight after settle.
I am more than happy with the slightly stiffer feel in the front end. Made sure I hit some jumps on the way home to check out entry and hard braking charachteristics... BIG improvement all around. I like the way it bites in the corner better both on & off-road.
The entire procedure takes less than an hour. We hope these photo's will help simplify things for you do it yourselfer's. Let me know if you have any questions.
Ontario folks, contact me for Trevors number if you would like to have this done for you.
I have booked an alignment for later today.
CHEERS!
Norm
P.S. Alignment Specs. to follow!
Good day Folks!
CHEERS!
Norm
