Hot coffee!
Hoverp
Central Montana
I want to replace the factory inverter so I can get a 1500 watt inverter , my question is can I replace the factory one with another and wire it right in where the old inverter was? ( where is it located anyway?) I want to be able to plug my new Oxx Coffee box ruggedized contractor grade Kurig (1450w) into my outlet in the cab.
Thanks!
The Car Stereo Company
here, on frf
you are best off adding an inveter. put it behind the rear seat. the oem unit is small and your new one wont fit.
Hoverp
Hoverp
Central Montana
Would you recommend using one of the aux switches then run the wires to the inverter under the backseat ?
gwpfan
I was going to say when you driving the streets it's easy to make coffee since you'll likely never spill it, then I noticed his location.
Too damn far out in the middle of nowhere when you want coffee!
SilentShooter
Siesta Key, FL
What do you all think? 15 amp aux switch to run the 1500 watt inverter?
Do you know how watts convert to amps? We are talking a 12v system so you are basically going to be running some serious power cables into your cabin. Also I would make sure you have a Deep Cycle Battery cause even with the Engine running you will be pulling SERIOUS Amps. 12v X 130 amp = 1560watts
