Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
Ford Raptor Forum Supporting Vendors
HM Racing Design
HM Racing Design Ford Raptor Long Travel Suspension
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="HM Racing Design" data-source="post: 387336" data-attributes="member: 9742"><p>At HM Racing Design we have a extensive history with Ford's, and more specifically Ford F-150's. For the past 14 years we have developed and produced THE kit for the Ford F-150, both for play and for racing. We have several purpose built Race Trucks running our F-150 suspension, from the Sportsman class to the Trophy Truck class.Thousands of hard racing miles and several championships are a testament to what our kits are possible of. Here are a few examples of said trucks mentioned above.</p><p></p><p>Ford F-150 1400 Class Champion 2008</p><p>[ATTACH=full]207740[/ATTACH]</p><p></p><p>Ford F-150 Trophy Truck Conversion</p><p>[ATTACH=full]207741[/ATTACH]</p><p></p><p>4WD Trophy Truck for Rod Hall Racing built by Samco running HM Racing Design 4WD Suspension</p><p>[ATTACH=full]207742[/ATTACH]</p><p></p><p>HM Racing Design built Class 8000 running our F-150 Suspension</p><p>[ATTACH=full]207743[/ATTACH]</p><p></p><p></p><p>With our extensive history with the F-150, we tackled the Ford Raptor.</p><p>We developed this kit with our racing heritage in mind. We wanted a kit that would make the ultimate Raptor, one that complimented the aggressive styling that has made the truck so popular. Here are the complete specs on the suspension components:</p><p></p><p>Track Width: </p><p>94 inches</p><p>[ATTACH=full]207744[/ATTACH]</p><p></p><p>Travel Numbers:</p><p>18.5 inches of Travel with 4WD</p><p>[ATTACH=full]207745[/ATTACH]</p><p></p><p>Whats included in the Long Travel Set-Up:</p><p>-Chromoly Upper A-Arms for unparalleled strength. 7/8" FK series heims connect the upper A-Arms to the frame at our custom A-Arm mounts.</p><p>-Chromoly Uprights designed to fit the stock 4WD hub.</p><p>-Chromoly Lower A-Arms with sunken shock mounts. These lower A-Arms connect to the factory frame with 1" FK uniballs for increased rigidity.</p><p>-7074 Machined Aluminum tie Rods.</p><p>-Custom clevises for complete heimed steering.</p><p>-PRP triple stitched limit straps </p><p>-Custom steel braided brake lines</p><p>-All grade 9 aircraft grade bolts. tensile strength of 200,000 psi</p><p>-Heat Treated stainless steel spacers at all heim and uniball pivots</p><p>-Custom upper A-Arm mounts</p><p>-Powdercoating included. Titanium or are our standard color, but any color can be chosen if specified.</p><p></p><p>Please call us at the shop for pricing. Phone number is 951-304-3132 or email us at <a href="mailto:kevin.hnm1@verizon.net">kevin.hnm1@verizon.net</a>.</p><p></p><p>[ATTACH=full]207746[/ATTACH]</p><p>[ATTACH=full]207747[/ATTACH]</p><p>[ATTACH=full]207748[/ATTACH]</p><p>[ATTACH=full]207749[/ATTACH]</p><p>[ATTACH=full]207750[/ATTACH]</p><p>[ATTACH=full]207751[/ATTACH]</p></blockquote><p></p>
[QUOTE="HM Racing Design, post: 387336, member: 9742"] At HM Racing Design we have a extensive history with Ford's, and more specifically Ford F-150's. For the past 14 years we have developed and produced THE kit for the Ford F-150, both for play and for racing. We have several purpose built Race Trucks running our F-150 suspension, from the Sportsman class to the Trophy Truck class.Thousands of hard racing miles and several championships are a testament to what our kits are possible of. Here are a few examples of said trucks mentioned above. Ford F-150 1400 Class Champion 2008 [ATTACH=full]207740[/ATTACH] Ford F-150 Trophy Truck Conversion [ATTACH=full]207741[/ATTACH] 4WD Trophy Truck for Rod Hall Racing built by Samco running HM Racing Design 4WD Suspension [ATTACH=full]207742[/ATTACH] HM Racing Design built Class 8000 running our F-150 Suspension [ATTACH=full]207743[/ATTACH] With our extensive history with the F-150, we tackled the Ford Raptor. We developed this kit with our racing heritage in mind. We wanted a kit that would make the ultimate Raptor, one that complimented the aggressive styling that has made the truck so popular. Here are the complete specs on the suspension components: Track Width: 94 inches [ATTACH=full]207744[/ATTACH] Travel Numbers: 18.5 inches of Travel with 4WD [ATTACH=full]207745[/ATTACH] Whats included in the Long Travel Set-Up: -Chromoly Upper A-Arms for unparalleled strength. 7/8" FK series heims connect the upper A-Arms to the frame at our custom A-Arm mounts. -Chromoly Uprights designed to fit the stock 4WD hub. -Chromoly Lower A-Arms with sunken shock mounts. These lower A-Arms connect to the factory frame with 1" FK uniballs for increased rigidity. -7074 Machined Aluminum tie Rods. -Custom clevises for complete heimed steering. -PRP triple stitched limit straps -Custom steel braided brake lines -All grade 9 aircraft grade bolts. tensile strength of 200,000 psi -Heat Treated stainless steel spacers at all heim and uniball pivots -Custom upper A-Arm mounts -Powdercoating included. Titanium or are our standard color, but any color can be chosen if specified. Please call us at the shop for pricing. Phone number is 951-304-3132 or email us at [email]kevin.hnm1@verizon.net[/email]. [ATTACH=full]207746[/ATTACH] [ATTACH=full]207747[/ATTACH] [ATTACH=full]207748[/ATTACH] [ATTACH=full]207749[/ATTACH] [ATTACH=full]207750[/ATTACH] [ATTACH=full]207751[/ATTACH] [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
RedMBaron
Frogger22
Roush2568
TexAg2003
scmustang
Comish
Dunerking
springnthings
jk47
RJackson
chenner
Sharpie69
PdamnR
MDJAK
JCU Delt Ox
Corey C Stone
njhummer18
ToadSmasher2K1
Bubbasuwannee
chadinokc
Big Blue
MurderedOutSVT
dj30417
stiknrun
CleverGirl_
jAKe47
NES431
FivePointO
kylesatx
AARaptor
bachfool
10SpdsOfFury
GCATX
1268
ivo88
Zeusmotorworks
Carter Korb
trav7314
taquitos
DLaw0522
OKflyswatter
Dnpbakon
shank_guru
CDTX
BadWRP
Hagdio72
JimmyCee
Spike Spiegel
Jmeo
... and 23 more.
96,853
60,803
sethkbrown
Forums
HM Racing Design
Accept
Learn more…
