hidden winch mount installed
uaq69
i purchased the mount kit from SDHQ and i installed recon 10,500LB on it the complete items costed me around 800$ if i purchased warn it will cost a lot more but the recon can directly fit the mount
CineSLR
Roaming Shutterbug
New Orleans, LA
It will be interesting to hear your thoughts on the winch after a few uses! Nice piece of mind, thats for sure. Thanks for the pics!
Yukon Joe
Trafford, PA
I like the set up and I'm looking to do the same thing. Do you have any install tips you can provide? Where did you pick up the winch? Does recon not have a mount plate that fits with the Raptor?
Thanks!
U
uaq69
Thanks!
i made a good research about this i can't find recon one but the sdhq mount is a perfect direct fit i think add and out law raptor they also have the hidden mount but m not sure if it fit recon winch but the sdhq i tried it my self mmm and i think with recon winch its the cheapest winch and mount you can find
---------- Post added at 10:21 PM ---------- Previous post was at 10:20 PM ----------
Is that thing mounted to the bumper or the frame??? eek
to the frame
Yukon Joe
Trafford, PA
I would think it would fit.
The mount plate connects to the frame via the recovery hook bolts. The bolts should be long enough to accommodate both the winch plate mount and the light bar. If not, buy some grade 8 bolts that are longer.
Joe
