Looking at buying the BakFlip HD bed cover for the raptor but have some questions on the install I'm hoping someone here can help with.
I have the ford plastic bed liner installed. The directions state no drilling required for the rails so I assume I have to remove the top moldings so I can get to holes behind the liner and drill through bed liner?
Also, it states you have to drill two drain holes, I thought our trucks have this already drilled? If so, then what has to be done to get both drain tubes installed.
How do you like the cover overall?
Thank you for the help!
