Help! Baja Designs LP6 to upfitter
4x4TruckLEDs.com
Good deal. I ended up making my own harnesses for my truck when I did mine. But if I had to do it again, i'd probably just use the Baja harness and cut the wires off. Now, my harness IS really nice and customized for my truck with all the cables I need. BUT it took some time to make them.
Raptor911
Ashburn, VA
OP .... I assume that is a SVC bumper with 4 LP6 light tabs?
Do you think there's enough room to run 5 LP6s?
Thanks you guys! I did it today, wasnt that bad. As 4x4 said first i cut the toggle off. I found through trial and error it was a white wire that went to the toggle that i was able to hook straight to upfitter switch for high beam. This is still using the BD relay provided. A red one was low beams. Then i ended up cutting the whole thing up to shorten the power and ground as well as the very long feed to the lights. I opted to also run backlit on all LP6s on an upfitter too instead of tapping DRL. Backlit is the yellow wires, all 4 can run on 1 switch with no relay. Hope this post helps someone else. Thanks again!
Steve_S
USA
Love this look. Well done!
Froadin
San Diego
Anyone seen this BD wiring harness? I just installed LP6’s with it and it was super easy. Designed to wire directly into the upfitter wires. No more wire massacres. A little too late for some though. Hopefully saves someone time and energy down the road. Install difficulty rating- 1 beer!!!
Steve_S
USA
