Heads Up! Guys with OE Beadlocks getting an Alignment
hosseface
Work
Alright, Long Story -
So I have the OE Beadlocks. I did mid perch on my truck Tuesday & an alignment at my shop.
I have one of the best alignment machines you can buy - A brand new Hunter Hawkeye Elite with the adapters that don't "clamp" the wheels - they just clamp the tires and have a soft "rubber" wheel protector to cushion the area where the head touches the wheel.
If anyone with OE beadlocks goes in for an alignment:
Make sure the shop either puts masking tape on your wheel between the alignment adapter and the wheel or make sure they put a fender cover or microfiber towel or something along those lines in between the alignment head and the wheel because the "damaged free" heads WILL SCRATCH our beadlock wheels!
I found out the hard way. I took my alignment readings before I did the perch adjustment just to compare before and after readings.
I then pulled the OE BFGs off and popped me on some bad a$$ Nitto Trail Grappler MT tires,(that's another story - I love them!), raised my truck to mid perch and did the final alignment.
After I took the initial readings when I was putting on the Nittos, I noticed those stupid heads scratched the heck out of my wheels. It took me about 3 hours with scratch x and a high speed buffer to get the scratches out.
I guess those heads are meant to work with aluminum and chrome wheels. You don't really see too many wheels that are actually painted like the OE beadlocks.
Just a heads up. Also threw in some before and after pics.
BAJASVT
SE Michigan
What about removing the beauty rings before doing the alignment? If you remove the ring, Is there anything for the alignment heads to attach/clamp to?
Ramrodthrusterpuppy
Ottawuh, Canaduh!
This^
When I had my 37s mounted, I had the shop remove the beauty rings so they wouldn't get scratched. Yeah, it's a bit more time for them but they were happy to do it in order to mitigate the risk of scratching up my expensive wheels. Underneath the ring, it is a typical wheel with a bead rim.
As far as purchasing the beauty rings separately...I've tried several dealers and they all quoted prices for the whole wheel, not just the ring.
