Has anyone installed the E&G half console vault in a 2025?
GordoJay
Colorado
Because mine isn't fitting. Driver's side rear of the vault where there's a notch cut out of the corner isn't the same shape as the inside of the console. It looks like the notch needs to be enlarged or the corner cut off.
jkenn6
NJ
They changed the center console a bit - I just went through this with the center console dividers.
CoderRaptor
Denver
I installed the full sized console vault from Ford. It was a pain. The trick if I remember correctly was to unfold it while it was in the console versus trying to fit it in the console already extended. So you put the collapsed vault in the console then lift up from the lid. It didn't seem to fit until I went about it this way. BTW, mine is a 24. --GL
GordoJay
GordoJay
Colorado
I got it in there. Had to cut one of the corners off, the driver's side rear. 45 degrees to the corner of the notch. After that it went in. It took a lot of pressure on the lid. Like get in the back seat and pull hard with my elbows can't believe it didn't break hard. But it went in twice and out once, so I'm just a **** I guess.
