roscopeeco78
- Joined
- Jan 8, 2017
- Posts
- 128
- Reaction score
- 63
Top of the morning to you,
I am looking to hardwire my dashcam to my pass-through wires that are located under the passenger side fuse box.
My goal is to have the dash cam connected to power always. I understand the premise of taking the hot wires under the hood and connecting them to the corresponding pass through wire under the hood. I am trying to figure out which upfitter switch I want the dashcam connected to.
Once I make the connection with the hot wire (aux wire) to the pass through wire under the hood, I plan on running a hardwire cable above the head liner and down the passenger A pillar and connect the wire to the corresponding pass through wire at the location of the passenger side fuse box. The circuit will be grounded to the nut and bolt conveniently located on the frame.
I have a few questions.
1.) Which aux switch would you connect the dash cam to?
2.) Which hard wire cable do you recommend?
3.) I don't need to mess with anything like connecting a fuse because the way the raptor aux switches are wired?
4.) If you see anything in the above that doesn't make sense or my understanding of the way this works is incorrect, please let me know.
