Gen2 Starter Removal
Clockton
Northern CA.
Has anyone had experience replacing their Gen2 starter? My Ford dealer can't find a way to remove the starter as it bumps into the LCA reinforcement. Who knows the trick to slide it out so I can do a swap?
Thanks
FordTechOne
Detroit
You have aftermarket LCA reinforcement brackets? If they're in the way they'll need to be removed, if they're welded then they may need to lift the engine off it's mounts.
blwn
Florida
ReconReggie19
Louisiana
Thanks
The best possible solution I would give you is.....find another Ford dealership. They can't even fix their own truck:wtf2:
NickW
Carbondale, CO
I made a thread in the engine discussion forum asking the best way to remove the starter, but no luck yet. Has anyone figured out the easiest/quickest way to remove the starter?
