GEN 2 WeatherTech front flaps
solarwinds
DFW
arrived, installed, took about 2 hours. probably approx 12wrhp and 14ft/lb tor gain :crazy:
but for realz it seems a little low hanging for front and will get beat up off road. i guess the mud guards if they come out are shorter but i might just get the dremel out and make that happen.
whaler230
Looks great, I have always liked Weathertech products but they never offered any for Raptors before. Did you use their hardware or the Ford screws already on the flare?
solarwinds
solarwinds
DFW
it uses the factory screws. nothing needed just the plastic flaps from WT
FRDRPT
Anyway you could put up a couple of more pics from the same angles, but from further back showing the whole truck? Sorry for asking, but it looks like you are the first one with these.
solarwinds
solarwinds
DFW
i second this, looking into a pair for front and rear, would like to see how they look at more of a distance.
you guys are more work than my 3rd wife :ROFLJest:
AKSteve
Got a set of front mud flaps delivered the other day and couldn't find my small ratchet set to install them and then noticed they have rears available so I have a set of those on order now also. I'll most likely have both sets installed early next week. Avalanche gray is pretty easy to keep looking clean except for the fact that if you drive through any puddles, your front tires spray filth all along the side of the truck at a 45° upward angle. These flaps should help out a lot with that.
