Gen 2 Raptor Icon Vehicle Dynamics Stage 2 Kit IN STOCK READY TO SHIP
customtruckshop
LGE-CTS Motorsports
San Dimas, CA
We now officially have the Stage 2 Icon kits in stock for the Gen 2 (17-18) Raptors
KIT INCLUDES:
3.0 Series Coilover Shock Kit
Adjustable coilovers yield 1-3” of front lift height
Increased wheel travel and vehicle specific valving provides unrivaled ride quality across a wide range of on and off-road use
50% increase in damping ability over OE shocks for excellent performance in extreme off-road conditions
Superior low speed control reduces body roll and increases on-road stability
Easy-to-adjust CDC Valve (Compression Damping Control) has 10 compression damping settings to suit all types of driving styles across varying terrain and vehicle cargo setups
ICON’s multi-stage hydraulic “Bump Zone” exponentially increases bottom-out resistance in the last 40% of compression travel
10" finned aluminum reservoirs provide generous oil volume and increased surface area for enhanced cooling properties and consistent damping
Barreled coil spring design maximizes travel and provides more efficient packaging
High quality ICON-engineered coil springs are guaranteed for life against sagging or breakage
Heavy duty CNC machined 1” shock shafts
FK Rod End COM12 spherical bearings ensure maximum strength and durability
CAD plated shock body with hard anodized piston and top cap
Fully serviceable design allows for revalves, rebuilds, and an immeasurable service life
Bolt-in design makes for an easy install into OEM shock location
“ICON 1K” tested under rigorous off-road conditions to validate tune, performance, strength, and durability
3.0 Series Rear Bypass Shock Kit
3-tube bypass design and "Bump Zone" technology provides multiple unique zones of damping and rebound control
12" finned aluminum reservoirs provide generous oil volume and increased surface area for enhanced cooling properties and consistent damping
Offset upper eyelet with patented ICON Anti-Wobble link for optimized shock mounting and packaging
Easy-to-adjust detented knobs offer quick adjustability without the use of tools
Specially engineered damped valve stops for quiet and precise operation without the loud “clicking” noise common with other brands
Urethane shin guards help to protect the shock shaft & rod end from premature wear
Delta Joint Billet Aluminum Upper Control Arm Kit
CNC machined 6061 billet aluminum construction for light weight and exceptional strength
Features ICON's Delta Joint
Camber and caster adjustability allows for precise wheel alignment
ICON double adjuster sleeves allow for on-vehicle adjustment
Vehicle specific taper pin provides OE-like fitment
PTFE Lined 7/8” FK Rod Ends for improved response
Built in o-ring sealed dust cover cap
FREE SHIPPING!!!!!!!!!!! *Lower 48 states*
Call or email for pricing!
[email protected]
(909)599-2228
Install deals available! Located in Southern California
