Sam C
Greetings All, my 2012 Gen. 1 has gauge cluster issues following installation of an aftermarket face and pointers. Any recommendations on gauge calibration or repair shops?
Thanks -
Thanks -
Hah, appropriate response. The upper instrument pointers are not accurate, probably were not returned to the correct "resting point". What is the best way to correct, should I remove pointers and place at bottom of gauge range or spin pointers counter-clock wise to lowest gauge reading ?
i believe so. when i called in for a replacement, they wanted the vin and mileage and verified our shopThanks for the insights and advice, I'm going for the "push with the engine running", have already removed the needles and repositioned. Prepared for failure, is a replacement inst. cluster a Ford OEM only part?
My system of "I'm out of ideas, let's try this". I'm glad it worked for you. A phrase I use often is "It ain't stupid if it works." It's been a few years since I had to fix mine - so far so good.Dane, your system worked! I have all the upper gauges properly aligned. Now when they "settle" each time they rest a little more to the low side.....seems possessed.
