Gen 1 Icon 3.0 RXT Rear Shocks
tcm glx
Riverside Ca
One Pair, brand new shocks.... in boxes. Minor scuffs if anything from being moved around. Had picked these up for my Gen 1, but sold and went on to a gen 3. Have both passenger and driver side. New In Box, ready to ship or pick up locally. $SOLD
Text for quickest response: 626.831.4446
Link: https://www.iconvehicledynamics.com/accessory/15968/icon-accessories-icon-2010-14-ford-raptor-rxt-30-zeta-remote-reservoir-shock-driver-side/
Features & Benefits​
  • 3.0 RXT 3 tube bypass rear shock with 3.0 remote reservoir
  • Unique side-mounted upper eyelet allows for increased up-travel while utilizing factory mounting location
  • Recirculating Dual Hose Reservoir (Patent Pending) keeps shock temperatures low by pumping heat to the reservoir for increased dissipation
  • Anti-Wobble Link (Patent Pending) keeps bypass tubes clear of leaf spring and tire
  • Easy-to-Adjust detented adjustment knobs offer quick adjustability without the use of tools
  • High resolution bypass valves designed for noticeable fine tune adjustments in rebound and compression
  • High flow CNC machined welded bypass blocks designed to increase fluid flow for enhanced performance & high definition tuning
  • Replaceable bypass tubes that can easily be replaced if damaged
  • Direct bolt in to OEM location with bypass adjustment knobs easily accessible for tuning adjustment
  • Special engineered damped valve seats for quiet and precise operation without the standard bypass loud “clicking” noise you will find with other brands
  • Multi stage cad plated finish with polished and anodized top cap / rod ends
  • Protective shin guards standard with every shock
