GEN 1 Gen 1 Guage cluster readout accuracy.
Johnny Psyhos
Illinois
Hey all, so i looked around and didnt find anything on this topic, so i figured id put this idea out there and see if we can find a solution. The guages on our trucks that read temps and pressure seem to be dummy gauges. (as long as the trucks engine/trans is at the expected parameter for the given circumstance the gauge will be in the middle)
For example, at high rpm the oil pressure is high, thats how it should be therefore the gauge sits in the middle.
Well id like to know what my oil pressure really is. when the truck is idling, the guage should be down low, and if im at redline, that needle should be close to maxed out. same for the coolant guage. if my engine is at 240 degrees, that needle should be in the upper 3/4.
So my question is this: How do i get them to read accurately. call me crazy, but if i payed for 6 guages on my dash, i wanna use 6 guages.
and yes, I know that getting a tuner screen would show that data, and i have one. but that screen is better off being used to show data that my truck isn't able to read from the factory gauge cluster.
I recall seeing a stainless steel plate on the internet floating around that would actually go over the faces of the gauges and add graduations to them - that would be cool to have - if the gauges read properly
