Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford F-150 Raptor General Discussions [GEN 2]
Fuel Treatment Product
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Dachuri" data-source="post: 1186195" data-attributes="member: 23731"><p>The new 3.5L Ecoboost (both high output version in the Raptor and standard version in the F-150) have both port and direct fuel injection, which is supposed to help keep the injectors cleaner than direct injection alone.</p><p></p><p>FWIW, I owned a 2012 Ecoboost for 5 years and almost 50,000 miles and didn't have any challenges with the valves (or any portion of the engine for that matter). I also used Gumout Regane (contains PEA) religiously every 3,000 miles and never drilled a hole in anything. Truck had bald tires, dead battery, leaking rear diff, a broken sunroof track and leaf springs that would shift and clank around with every turn (2 different dealers tried fixing with zero results) when I traded it in for my Gen2, but had I zero problems with the engine while I owned it.</p></blockquote><p></p>
[QUOTE="Dachuri, post: 1186195, member: 23731"] The new 3.5L Ecoboost (both high output version in the Raptor and standard version in the F-150) have both port and direct fuel injection, which is supposed to help keep the injectors cleaner than direct injection alone. FWIW, I owned a 2012 Ecoboost for 5 years and almost 50,000 miles and didn't have any challenges with the valves (or any portion of the engine for that matter). I also used Gumout Regane (contains PEA) religiously every 3,000 miles and never drilled a hole in anything. Truck had bald tires, dead battery, leaking rear diff, a broken sunroof track and leaf springs that would shift and clank around with every turn (2 different dealers tried fixing with zero results) when I traded it in for my Gen2, but had I zero problems with the engine while I owned it. [/QUOTE]
Insert quotes…
Verification
Post reply
Staff online
Big Blue
Administrator
Members online
Roush2568
RedMBaron
TexAg2003
scmustang
Comish
Dunerking
springnthings
jk47
RJackson
chenner
Sharpie69
PdamnR
MDJAK
JCU Delt Ox
Corey C Stone
njhummer18
ToadSmasher2K1
Bubbasuwannee
chadinokc
Big Blue
MurderedOutSVT
dj30417
stiknrun
CleverGirl_
jAKe47
NES431
FivePointO
kylesatx
AARaptor
bachfool
10SpdsOfFury
GCATX
1268
ivo88
Zeusmotorworks
Carter Korb
trav7314
taquitos
DLaw0522
OKflyswatter
Dnpbakon
shank_guru
CDTX
BadWRP
Hagdio72
JimmyCee
Spike Spiegel
Jmeo
Whit
... and 23 more.
96,853
60,803
sethkbrown
Forums
Accept
Learn more…
