Fuel System Cleaner
Corey77
I usually put a fuel system cleaner in my gas tank after every oil change to clean the internal parts. Any remommendations for the 17 Raptor? I usually use STP but not sure if this will be sufficient with this new truck.
Corey77
Corey77
Thanks Siooss! Looks like you need 2 bottles for each time with the 36gal tank. I'll order some and give it a try
dewalt
Sea foam as good as it gets and better than most. Really works good on ethanol crud in carbs
Otis857
Glendale, az
What's a carb? HA. You should see how so many of the young kid mechanics right out of trade school are lost when you talk about carburetors.
kdub405
Nothing better than a beer and carb tuning!
siooss
Florida
Check the ingredients in the product's SDS.
The active ingredients which help remove the deposits are chemicals known as Polyisobutene(PIB), Polyisobutylene Amine (PIBA) or Polyetheramine (PEA), with PEA being the most effective.
Amsoil P.i. contains PEA.
PIB removes water from system and keeps new deposits from forming. Does not remove existing deposits.
PIBA cleans the fuel system and removes any existing deposits. Requires less frequent applications than PIB cleaners.
PEA is the strongest cleaning agent available in fuel additives. It is more effective than both PIB and PIBA.
dewalt
Sea foam is isopropyl alcohol, pale oil and napha gas according to mds. Don't know how, but it works, gas or diesel in fuel. or oil if need be
