Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 2 (2017-2020) Ford F-150 Raptor Forums
Ford Raptor Suspension Discussion and Modification
FRS 3.0 in front or go oem Live Valve E-clik?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Space Ghost" data-source="post: 2091560" data-attributes="member: 59905"><p>may have issues full compression with that offset. Also the coopers are like 5lbs heavier per tire compared to oem</p><p>I know a member on here has fully compressed with 37 k02s on stock offset just fine. I dont mind a bit of rubbing when turning if it means its fully good to send it</p><p></p><p>Also like others, some wingnut put the locking screw on the backside of the shock so id have to yank them out again to adjust</p></blockquote><p></p>
[QUOTE="Space Ghost, post: 2091560, member: 59905"] may have issues full compression with that offset. Also the coopers are like 5lbs heavier per tire compared to oem I know a member on here has fully compressed with 37 k02s on stock offset just fine. I dont mind a bit of rubbing when turning if it means its fully good to send it Also like others, some wingnut put the locking screw on the backside of the shock so id have to yank them out again to adjust [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
themarcg
dkx01
wyomingraptor
icecoldak
YoshiTheRaptor
Raptorrunner
stevelp99
FishFreak
Starboy786
tractorpole
CrazyJeeper
taquitos
Chewie
Brapp_rap
96,807
60,783
yanni777
Forums
Accept
Learn more…
