Need some help! Have a 2017 Supercrew Raptor and removed the front license plate bracket in order to get the front end wrapped in film. Decided to install the bracket again and used an exacto knife to cut an "X" in the hole where the film went over the hole. Only issue, there seems to be some type of rubber piece directly behind the bumper holes because the knife only went in about 1/8" then after a slight pressure went in 1/4" until the knife bottomed out in the hole. Does anyone know what is directly behind these license plate bracket holes in the bumper? Seems like a piece of rubber or weatherstripping. Drove the truck quite a bit after remounting the license plate bracket and had no issues. Can't believe Ford would put some type of hose or anything major directly behind the holes. I ended up using 1" blue plastic drywall expansion anchors for the bracket screws to expand and hold the bracket in place when it originally had big rivets that I drilled out to remove. Any/all help that you can offer would be greatly appreciated.
Thank you.
Thank you.
