Front end rattle over bumps
Nick_Leadfoot
New Port Richey, Florida
Front end rattle while driving down bumpy roads. Noise is same in 2wd/4wd.
Tried removing both sway bar end links and noise was still there. Checked all heat shields, cv axles, ball joints, wheel bearings.
Passenger side cv axle has a lot of play at the front differential (not inner cv joint). Is this normal, bad needle bearing?
  • IMG_7249.mov
    11.4 MB
SCAR911
Arizona
Look at the top mount of the shock. I had similar and both sides had loose nuts on top.
