Normal
Here is how I get it so far... Lockpick will only work with the factory rear camera and does not currently offer a bypass if you have a factory front camera. If you buy a second camera you can bypass and make it work where ever you decide to mount it. So if you just don’t use the factory camera you could use a third party camera and view that. Lockpick is hung on the different modules it goes to prior to going into bypass mode. Currently if you went in to bypass mode you can interfere with proper operation of 4wd module. Also problem with if you are in bypass mode and shift to reverse there is an issue with the head unit video with both on at the same time... I don’t have the Nav-tv unit yet hope to have an answer tomorrow as to exactly when or if they will send me a test unit... hoping....
