letsgetthisdone
When I deleted mine I pulled ALL of the related vacuum lines between the solenoid and the IWE's out of the truck and I put a vacuum cap on the solenoid.
Got under the truck last night and found that the driver side axle has about 1/4” of movement in and out of the back of the hub. I’m assuming the axle nut has worked its way off. Looks like the nut does not support the hub bearing? I haven’t felt any vibration, so seems it just secures the shaft.
Vac tested the actuators and that side has a leak also.
Cant wait to delete these stupid IWE hubs.
Sounds like the axle nut. Just need to pull off the tire and dust cap to check that. As stated previously it's a low torque, but I always use loctite on it now. It's too prone to backing off. As you said, it doesn't support anything. It simply keeps the axle shaft in place and unable to float around causing improper engagement.
Leak in the IWE will cause your rattling issue. Out of curiosity, which side was rattling, the leaky side or the good side?
One FYI, when I was looking at the delete kit RPG advised me that RCV doesn't recommend using it in cold climates. I don't know the why, but living in the Denver area I qualify as cold, therefore I didn't do it. Looks like you are in Vegas, probably fine there, but a good factoid to be aware of.
