FlounderStalker
- Joined
- Jul 5, 2010
- Posts
- 306
- Reaction score
- 2
What size are the fox shocks on the Raptor and how much to they cost if you needed to replace them?
Other features of the SVT/Fox shocks are a 2.5-inch body, piggyback reservoirs on the rear, and a 7/8-inch shaft diameter. The shocks use 47mm pistons (compare that to 35mm front and 32mm rear piston size of the standard F-150) with 7.1 inches of front shaft travel, while the rears have 10.9 inches of shaft travel. This equates to an impressive 11.1 inches of front wheel travel (compared to 8.5 inches on the standard F-150) and 13.1 inches of rear wheel travel (same as the F-150) for the Raptor. While those numbers may not sound as good as some aftermarket long-travel kits, remember we are talking about bypass shocks here, which give beautifully controlled, clean travel. The Raptor is also very streetable and passes all of Ford's internal requirements for on-road handling.
Andy R, you are just about right. I had to replace my right front just this week due to it leaking. Parts manager told me list for the shock was $647.00
I don't know about size but someone told me a set of shocks for the Raptor will run 1200.00.
