FOX Quick Adjust Bypass (QAB) Technology Now Available
FOX
El Cajon, CA
Quick Adjusting Bypass technology is available as an option for all new 2.5, 3.0, and 3.5 FOX External Bypass shocks or as an upgrade.
The FOX Quick Adjusting Bypass (QAB) technology allows you to manually adjust bypass tubes, quickly and easily, making fumbling with tools and visually counting turns obsolete.
The CNC Machined 6061-T6 aluminum adjustment knobs—anodized blue for compression or red for rebound--are knurled for increased grip, with laser-etched arrows indicating adjustment direction. The adjuster has the same flow and range of adjustment as our regular bypass units. The new design has a definitive click at every quarter revolution of the knob, making adjustments simple and quick—tracking shock changes is now easier than ever. The knobs also feature an O-ring seal to keep moisture and contaminants out, insuring a reliable adjustment turn after turn.
The Quick Adjusting Bypass technology is available as an option for all new 2.5, 3.0, and 3.5 FOX External Bypass shocks or as an upgrade for your existing shocks. The QAB is also standard on the Ford SVT Raptor Rear FOX 3.0 Factory Series Bypass QAB Reservoir upgrade kits. Visit a local FOX Truck or Offroad retailer to purchase. Existing bypass shocks can be upgraded at the FOX Truck and Offroad service center in El Cajon, CA.
Ford SVT Raptor (Rear) 883-09-047 $2500.00 set retail
For complete product details visit: http://ridefox.com/raptorqab
FOX QAB Upgrade Kit
QAB Blue Compression Kit 815-03-010 $80.00 each retail
QAB Red Rebound Kit 815-03-011 $80.00 each retail
For complete product details visit: http://www.ridefox.com/upgrades
FOX
FOX
El Cajon, CA
---------- Post added at 01:21 PM ---------- Previous post was at 01:20 PM ----------
MTUH3
Plymouth, MI
Great idea!
Wanna send some my way for cold winter testing this year. wink wink.
I gotta get in touch with you guys on shocks for my other truck soon anyway.
Do you need to do a full shock rebuild to put these one, or can the be installed on the fly?
FOX
FOX
El Cajon, CA
Great idea!
To install the QAB requires removing of the existing bypass check valve hardware. To remove this hardware the oil will need to be drained and then bled after refilling.
MTUH3
Plymouth, MI
Code for Send my 3.0's to Fox or RPG and have them fix me up..... but this would be a good reason to practice my rebuild skillz
