Found a solid power steering fix!
btb5987
Howdy y’all!
I know that the power steering is a weak point on the raptors and after blowing up 3 pumps I decided to try to tackle it. I started with the icon cooler and res which helped but didn’t solve it. What I ended up doing was buying some ebay AN6 fittings and making a all new return system. It now runs from the pump to the built in cooler, to the aftermarket cooler, through a filter, and then back to my reservoir. For the filter I used a remote oil filter mount and machined a mount for it so that it sits by my drivers side headlight. This let’s me replace the filter with just a normal oil filter and without having to get under the car. I also bought a massive cooler off eBay and cut off the stand pipe it came with. This has worked extremely well and I recommend it to everyone who blows through pumps!
Here’s the link for the reservoir I used:
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/291946302581
Also attached is a picture of the filter set up.
Best of luck!
EricM
OHIO
Fram synthetic filters (Ultra Guard etc) are some of, if not the best filters on the market. This isn't 1997 anymore.
Dutch VC
Waterford Ct
Nice setup! Very clean. Do you have and picture of how it’s tied into the pump or are those the factory fittings?
