On my 2017 the DRLs was only on when Auto lights were on. I also had the measurement numbers set on. During service, I turned off the DRLs, just did not want to make it too obvious.Yes, that is one of the changes I made. DRL always on and the markers.
BCM | 726-22-01 | xxxx | xxxx | 01-- |
The "- -" is checksum data.Question. When looking at codes in forscan. And vs a cheat sheet to change values. What do the dashes represent? I know "X" means whatever yours has, leave it alone. But some codes show "- -" at the end of them. For example.
BCM 726-22-01 xxxx xxxx 01--
Should the "- -" at the end be what I see in mine? Meaning I should input 01-- or does it mean I just put 01 and disregard the last 2 digits?
Ah thank you! I got my global windows working just now. Bummed it only does the front windows, but thats better than nothing.The "- -" is checksum data.
You shouldn't need to adjust anything there. Forscan handles that automatically after you make whatever adjustments you are making elsewhere. My understanding is that if you get a "checksum" error waring to just ignore it and "write" anyways. Forscan should make the proper adjustments once you write it.
Yes, the “upgrade” tweak is fantastic! Give it a try; you definitely won’t be disappointed.Anyone else do the stereo tweak? I only see a few mentions of it here. Does it in fact sound much better?
