Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
RAM TRX - TRX-Forum.com
Forums
GEN 1 (2010-2014) Ford SVT Raptor Forums
Ford Raptor Suspension Discussion and Modification
ford raptor oem fox shocks coil options?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="SDHQJASON" data-source="post: 523629" data-attributes="member: 4893"><p>If you are wanting custom coil springs to change the spring rate, I would look into calling deaver and giving them the part number off a stock raptor coil spring. With this info they will have everything they need from the dimensions to the stock spring rate. Then they can go back and modify it to your liking. We have done it on race trucks before to get it dialed in.</p></blockquote><p></p>
[QUOTE="SDHQJASON, post: 523629, member: 4893"] If you are wanting custom coil springs to change the spring rate, I would look into calling deaver and giving them the part number off a stock raptor coil spring. With this info they will have everything they need from the dimensions to the stock spring rate. Then they can go back and modify it to your liking. We have done it on race trucks before to get it dialed in. [/QUOTE]
Insert quotes…
Verification
Post reply
Members online
CleverGirl_
Hambone
nikhsub1
970rap
cammac50
taquitos
KUSTOMZMAN1
stevenstommyboy1
ajm2332
RJackson
Hallboss
Mthon7
DinoNuggets
nealhoney
QtrHorse
GraniteGuy
New recaros
Skyfrog
ToadSmasher2K1
icecoldak
GordoJay
23Raptor23
Shane361
Todd Turbo S
bunkisland
Turning Blue
Zeusmotorworks
JohnyPython
Token
wyomingraptor
DAVfoto
bachfool
RoNiN Raptor
IHAVETWO
NickyF25
BeeEyez
thatJeepguy
Fender150
valley3
BP31
chris_tofu_r
Ilushikntu
TchokaEewe
96,865
60,820
abhinav
Forums
Accept
Learn more…
