Deleted member 12951
Guest
Got more or less a couple questions and do not know if it only pertains to the WSI HD springs or all others.
I thought with the stock leafs, the plate/bolts were parallel to the ground but to be honest, I am not 100% positive. After my WSI install I notice that they are at an angle. Using my iPhone level app I found that the driver side is at a 22 degrees and the passenger at 18 degrees. Is this how it is supposed to be?
Hope the pictures help.
Other question is the vacuum hose has clips that were both hanging free on each side. It seems they clip onto the rear bolts, it that right?
