Looks good. What process did you use? Wet sand or Denim pad? Did you use a paint thickness gauge?
I used the CarPro denim pads with a Flex 3401 buffer. I will be using the Flex PE-14 rotary buffer when my 5" plate arrives because it will cut faster then a da. I have a paint thickness gauge to make sure I am not taking too much off. Really what I am doing is slicing off the high points without taking any real amount of clearcoat thickness off. Only about 8-12 microns or 1/2 of a thousandth.
Thanks guys, the truck still has orange peel but it is drastically reduced from the original paint job. Here's another picture. View attachment 81106
