Factory BFG’s 35 Load Range E
Pacific Wheel
Reno, NV
Should be a C rating. Outside of a harsher ride there isn't much of difference. Both have 3 ply sidewall but the E can take higher PSI and carry more load. The load rating C is softer tread (probably why they wear quicker than the E) and has a higher speed rating (S vs T). But if the ride is good to you I'd probably consider it a blessing. Better wear and the weight is practically the same. Only a 1lb difference.
E rated
C Rated
Winchester30
WI
NASSTY
ME
What’s the difference other than $4 and “Ford performance” in the description?
The only difference I can see is the speed rating. The Raptor tires are "T" 118mph and the Jeep tires are "S" 112mph.
Trailmaker
Off-road junky
Conroe Texas
I prefer the E rated tire for my use I tow a little heavy, plus the trails I do go on are more rock than sand. No fun changing a tire out on a trail. So I would consider it a blessing.
