1BAD454SSv2
Swap coils with another cylinder and see if misfire moves to other cylinder. if it does it is the coil that's bad , if not could be a injector .
Yup, that was going to be my next step if I couldn’t find one in stock reasonably close by. A 1.5 hour drive each direction, but got the only one in San Antonio this afternoon… so much for reloading some 6.8 cases, and maybe even getting out to the range to enjoy this awesome weather we’re having today :-/Swap coils with another cylinder and see if misfire moves to other cylinder. if it does it is the coil that's bad , if not could be a injector .
If “Fordtechmakuloco” recommends a light coat, then that’s good enough for me.I was told not to run anti seize on spark plugs because it can cause issues.
His videos rub me the wrong way. If a tuner says it’ll foul the plugs then that’s good enough for me.If “Fordtechmakuloco” recommends a light coat, then that’s good enough for me.
