DougDimmadome
Those of you running e clik, when you change suspension modes on the truck, does that flow through to the suspension controller or does that button on the steering wheel basically become a fidget toy?
How do you set it most of the time?Both are operational, so if you set the E-Clik to desert and have the truck in Baja, it will be way too stiff, so I usually set the truck in whatever mode I want, put the suspension in “normal” mode and use the E-Clik rotary knob to setup the suspension from there.
