Drivers Seat Foam Awful, Replacement Part Number?
fur_pig
Hey guys,
Just bought a 2018 and the drivers side seat heater is inop and the foam is completely compressed. I tried finding the foam online but can only find it with the OSC sensor and heater element installed to the tune of $1200. Does anyone know if you can just get the foam and what the part number is? I'm getting conflicted info on all the go-to sites like Tasca and others.
Tasca says this will fit but wanted to run it by the masters first!
brianh87
Pittsburgh, PA
You're in luck! I'm literally replacing mine as we speak. Keep in mind, my model is a 801A so my cushion may be different because mine isn't cooled. Just heated. It also says the cushion comes with the heating element. It does not!
Driver side cushion - JL3Z-15632A23-A
Driver side cushion heating element - LL3Z-14D696-A
*Edited - I didn't mean to write "cover" for the driver side cushion. Parts numbers are correct though.
StraightSixM2C
NYC
Driver side cushion cover - JL3Z-15632A23-A
Thanks! I’m about do the same exact thing.
Donovan
DC
Good info to have on standby..
Pikser
Why use the cheap factory form ?
Find a local shop and get some of the better form.
nikhsub1
Los Angeles
Did anyone order this yet and install it? The description makes it seem like this is for the REAR seat...
brianh87
Pittsburgh, PA
After having done this, I do not believe the foams I listed could be used on the cooled seat version. They are only for 800A / 801A. The cooled version must be a different part number.
A little trick I learned is to setup an account on Fordparts.com. Add your own Raptor vin. You can search for the parts you need on that site, but unfortunately they do not provide the full part number until you place an actual order. But... You can find a part number on Tasca or wherever and input it into Fordparts.com. The part that comes up will tell you if it's compatible with your particular truck. I had to do this to get a new foam, heater, and leather seat cover.
